Thread: polaris booster pump
    Nov 2012
    Oklahomia
    Default polaris booster pump
    I have my polaris 380 set to run on a timer every day. I accidentally forgot to reconnect my Polaris to the pool after removing it for swimming one evening. Would this do any damage to the booster pump to run without the vacuum connected? The pump was very loud without the Polaris connected but seems to be running normally now.
    Virginia
    Default Re: polaris booster pump
    If it's running normally now, you probably dodged that bullet.
    +1
    When we had ours installed we were warned not to run the booster pump without the cleaner connected.
  1. Polaris PB-4 Booster Pump
    By snj2k2se in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 03:03 PM
  2. Polaris booster pump hose needs help
    By dawndenise in forum In-Ground Pool Construction and Repair
    Last Post: 08-28-2008, 10:53 AM
  3. Polaris booster pump rebuild
    By biker2 in forum Pool Equipment & Operations
    Last Post: 10-01-2006, 01:03 PM
  4. Polaris Booster Pump Rebuild
    By vgg659 in forum Pool Equipment & Operations
    Last Post: 08-27-2006, 12:27 PM
