Thread: The Pool Cleaner Made by Poolvergnuegen
    Nov 2012
    Default The Pool Cleaner Made by Poolvergnuegen
    I'm considering buying a new pool vacuum. For the past 4 years I've been using a Hayward pool vac but I'm tired of rebuilding it and it still not functioning correctly. I can't get it to stop getting hung up on the pool light, the drain at the bottom of the pool and also the corners of the steps. I'm tired of spending money on it. Has anyone had experience with The Pool Cleaner made by Poolvergnuegen?
    mas985's Avatar
    Pleasanton, CA
    Default Re: The Pool Cleaner Made by Poolvergnuegen
    I have had about 7 years experience with the 2x Suction side cleaner and I would highly recommend it. Great cleaner that requires less flow rate than most. The pressure side also has high recommendations from those who have one.
    Mark
    I have the Pressure Cleaner with my Intelliflo VF variable speed pump using a dedicated line that is automatically switched to when cleaning. I can do this because the VF can go down to 15 GPM. This let me get rid of a booster pump and saves on electricity costs.
    The cleaner is around 5 years old now and it's got a problem moving that needs repair so I'm sending it to the factory for them to look at. So cleaners do tend to have problems, some sooner and some later, but the company has always been good and honest about things, though in the past all I had to do was replace tire treads and bags.
