Results 11 to 12 of 12
Thread: new liner not flat against wall; has waves and puckers; fixable?
    Default Re: new liner not flat against wall; has waves and puckers; fixable?
    Thank you! I'm not holding out much hope, either. Maybe they can "spread" the wrinkles to make them less noticeable? If they can't fix it, perhaps it's time to bargain for a freebie, like an automatic vacuum!
    E think there is a VERY GOOD CHANCE that they will be able to make the wrinkles 'invisible' to anyone not looking for them.
    You ought talk to the PB and see what he'll do to compensate you for this.
    We can talk more over the winter or next spring, after they perform the 'fix'.
    Have great Thanksgiving! - I'm loading up the SUV to head to far western NY for the remainder of the week to spend time with family
  1. Proper way to install liner over top of wall
    By shovelrog in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2013, 07:10 PM
  2. Should inground vinyl liner be flat against pool side?
    By Janet in forum In-Ground Pool Construction and Repair
    Last Post: 07-21-2012, 10:44 AM
  3. Foam Wall Liner won't stay attached to pool wall
    By pdxpool in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2012, 04:24 PM
  4. I REALLY NEED HELP - New Liner, or is Mine Fixable?
    By Rowan555 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-23-2007, 10:43 PM
  5. IG vinyl liner pulling away from wall
    By spooky2feet in forum In-Ground Pool Construction and Repair
    Last Post: 04-02-2006, 09:59 AM
