Thread: Fiberglass resurfacing
    Nov 2012
    Sacramento, CA
    Default Fiberglass resurfacing
    Hi,
    I'm actually posting a question for a friend (but I happen to be a new pool owner too) that has an inground plastered pool with a crack that runs from the bottom of the pool in the shallow end up the side to the top of the pool. He is losing about an inch of water a day. He hired a leak detection company to verify the source of the leak. The inspector recommended resurfacing with fiberglass instead of plaster since fiberglass is a flexible material. If it were to crack again, the section could be repaired unlike plaster. Any thoughts on other options or feedback on converting to fiberglass surface. Thanks!
    Default Re: Fiberglass resurfacing
    I've never seen a fiberglass resurface job that went well. I think it *can* be done, but it's very, very skill dependent work, and unless you get a highly skilled AND conscientious installer, I doubt you'll be pleased with the results, after the first year or so.
  1. Pool resurfacing
    By Lori O in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2013, 10:56 AM
  2. Resurfacing a plaster/gunite pool with fiberglass
    By casicielo in forum In-Ground Pool Construction and Repair
    Last Post: 05-28-2013, 08:43 PM
  3. Pool resurfacing
    By ettienne in forum Pool Equipment & Operations
    Last Post: 05-15-2012, 07:56 PM
  4. resurfacing pool...
    By Henrys514 in forum In-Ground Pool Construction and Repair
    Last Post: 06-07-2006, 10:23 PM
