Thread: How Much FC To Make Water Potable?
    May 2012
    Florida
    Default How Much FC To Make Water Potable?
    i figured this was a good place to discuss this with some of you guys/gals who know WAY more about chlorine than i do.
    a handfull of times a year go camping and hiking. as you can imagine a full pack of gear gets heavy when you carry everything you need for a few days. while i do take water with me im limited to how much due to space and weight. sometimes i will hike 4 plus miles into the woods and im often forced to drink water from some very questionable sources like this.
    i know that these watering holes are not only used by me, but they are also a source of water for all the critters in the woods. there is no question that there are all kinds of crap in these holes like animal feces/urine, baceria, virus, cyst, etc...
    i currently use a mechanical filter that will filter down to .3 micron. the filter also has activated charcoal inside to help with filtering. once my water bladders and bottles are filled i follow up with a chemical treatment. ive used a two tablet treatment that uses 1 tablet of iodine and one tablet of another chemical to get ride of the iodine taste. they seem to work as i have not gotten sick, but i have read that iodine will not get rid of crypto. there is also almost an hour wait time for the chemicals to do their thing.
    a while back ( before learning a little about chlorine ) i purchased a very expensive 2 ounce bottle with a chemical in it that was supposed to be good at killing the nasties... turns out that very expensive chemical is nothing more than 3.5% sodium hpochlorite! i found this out as i was checking the bottle for an upcoming trip as i remember it having an experation date on it. i kicked myself in the butt after realizing that i spent 15.00 on 2 ounces of bleach!the other 96.5% in the bottle must be made up of fairy dust and unicorn blood... i guess thats why i cost's so much!
    the instructions say to use 5 drops per liter of water ( the water should be as clean as possible ), mix and wait for 10 minutes before drinking. i wanted to test this to see how much FC the 5 drops will give in 1 liter but its old and im sure its not a full 3.5% sodium hpochlorite any more. my plan is to fill my 2 ounce bottle ( which is about identicle to the taylor bottles ) with fresh bleach which is 8.25% and use it on some of this dirty water to see what kind of FC levels i get from a certain amount of drops.
    so here is my question. what is my target FC for making water safe to drink? i know other things will effect my FC like how much critter poop is in the water, but will water temp and PH play a role in any of this? also, what FC levels are safe for drinking?
    there are other chemical treatments like chlorine dioxide tablets, and from what i have read they are better than iodine and chlorine for killing nasties, but these tablets have a 4 hour wait time before drinking so i have not used these yet.
    here are pics of my filter in case anyone was wonder anything about that...
    18' round 7.5K gal AG vinyl pool; bleach; waterway cartridge filter; waterway pump; 12hrs; taylor k-2005 and taylor k-1515a; utility water ; summer: none; winter: none; ; PF:16
    Default Re: How Much FC To Make Water Potable?
    Since you are concerned about Crypto, you don't want to use chlorine since that will take too long to inactivate it. I suggest you take a look at Katadyn Micropur MP1 Purification Tablets that are a combination of sodium chlorite and Dichlor that when dissolved in water will generate chlorine dioxide that will kill Crypto though it takes 30 minutes in clear water and 4 hours in cold and extremely dirty water. Everything but Crypto is killed within 15 minutes.
    Thanks for taking this one, Richard!
  1. dpt powder doesn't make water turn pink
    By marciastz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2009, 01:12 PM
  2. Make sure I have this right - TA and CH
    By Trimom in forum Dealing with Alkalinity and Calcium
    Last Post: 06-19-2007, 04:37 PM
  3. Tiny microbubbles make water look cloudy
    By cygnusecks in forum Pool Equipment & Operations
    Last Post: 08-31-2006, 09:16 PM
  4. Make sure I got this right...
    By steveinaz in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-04-2006, 02:52 PM
  5. NEWBIE - How to make fresh water ready to swim?
    By bluenote in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2006, 06:03 PM
