Thread: Aerating... Question.
    Default Re: Aerating... Question.
    Part of the problem is in your method...here's the link to the method that works....http://www.poolforum.com/pf2/showthread.php?t=191
    To aerate your pool, aim your return toward the surface of the water so that it creates ripples. You can buy a cheapie fountain and use that to aerate, or you can put a bunch of kids in the pool to play and splash around, which actually seems to work best!
    Joliet
    Hi Fueller,
    Being a new pool owner mysefl...I was thankful to find this site and REAL solutions to the chemistry problems we may be having with our water.
    I recently used the method, linked to above by aylad. My TA was succesfully lowered to 130 from 290. PH is currently 7.3.
    good luck!
    dan
    Thanks... I was looking at a Fountain today, but wasn't sure if that was the answer or not. I did point the return toward the surface, but I am getting minor ripples across the water. My main concern is my heater. The Pool store has me pretty much scared to death that if I drop my pH it will destroy it in no time.
    Had a pool party today, hope that helped...
