Thread: Is there an optimum pump strength for my filter/pool?
    Oct 2012
    New Jersey, USA
    Default Is there an optimum pump strength for my filter/pool?
    I have a Hayward Perflex DE filter on my pool, which is an in-ground, 40x20 footer with 40,000 gallons.
    Currently, it's got a 3/4 hp pump attached to it. We ran it for eight hours daily over the summer and we had no trouble keeping it clear at all.
    My brother feels that if we got a 1 hp pump, we could cut the daily runtime to 6 hours and still get a complete cycling of the water. However I've read that having a too-powerful pump can have the effect of blasting debris and such through the DE in the pump and actually reduce the filter's efficiency.
    Could a stronger pump be better for us, or should we just stick with what we've got?
    Default Re: Is there an optimum pump strength for my filter/pool?
    There are folks on this forum who can advise you on this, but I'm not one of them. I will get an email out to the ones that can, though, and ask them to check in here and offer an opinion. MIght take a few days before they get a chance to stop by, so don't give up!
    Oct 2012
    New Jersey, USA
    Thanks. I forgot to mention in my first post that the model number of my Perflex is EC-75. It's documents online show that it ships with a 1.5 HP superpump, so I don't know why I have a 3/4 HP pump on it (it's been there since before I started caring for the pool).
    mas985's Avatar
    Pleasanton, CA
    You are far better off with a smaller pump even if you run it longer. Smaller pumps are usually much more efficient at turning over a pool than a larger pump. So I would stick with the pump you have. It is more than sufficient even for that size pool and you are correct about putting to much flow rate through a filter but it depends on the size of filter. You may even be able to shorten the run time if you want to save on energy costs.
    What is the brand/model # of your pump and filter?
    Mark
    Oct 2012
    New Jersey, USA
    Thanks for the reply. Its a Hayward Perflex ec-75 filter with a 3/4 HP super pump.
    Like I said, it worked fine over the summer. However, the pool was out of commission for a couple of years and we only got it up and running mid-August, when we had the liner and some of the piping replaced. So, I have not used it for spring clean up, and in fact only rarely used it for vacuuming because I usually use a Pool Blaster Max for that.
    mas985's Avatar
    Pleasanton, CA
    The 3/4 HP superpump is a great pump and one of the most efficient single speeds on the market so I wouldn't change it until it fails.
    Mark
  1. Is Super Algae 60% strength the same?
    By debs_pool in forum Dealing with Algae & Slime
    Last Post: 07-30-2007, 08:32 PM
  2. Optimum PH for pool closing
    By Rangeball in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-01-2006, 11:18 AM
  3. Testing Bleach Strength
    By fcfrey in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-14-2006, 12:13 AM
  4. Test chlorin strength?
    By xoroniox in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-28-2006, 03:18 PM
  5. Optimum Levels?
    By jen in tx2 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-16-2006, 05:12 PM
