Thread: GAS or Electric Heat?
    Jun 2011
    Sacramento, CA
    Default GAS or Electric Heat?
    I live in a PG&E/SMUD area: Sacramento, CA.
    I currently have a balanced plan with both.
    I have a 24000 gallon free-form in-ground pool plastered.
    Rarely freezes here, and winter extreme lows are in the high 40's.
    Summers are close to and sometimes over 100.
    I was wondering what would be cheaper to heat the pool in the fall/winter: Gas or Electric?
    I currently run an AC/Heat on the roof, with a gas line.
    Also there is a gas outlet next to the pool pump.
    Which leads me to believe that originally the pool was heated when
    the house was built in 1967.
    Thanks a bunch! Mark
    Default Re: GAS or Electric Heat?
    "Which would be cheaper, gas or electric heat?"
    Depends on 2 factors:
    1. Which sort of electric heat were you considering, resistance or heat pump?
    2. What are your incremental gas rates; what are your incremental electric rates. (You need the incremental value, since rates for your first 1000 KWH or 100 CCF are often cheaper than for additional usage.)
  1. DIY electrical wiring for the pool
    By celery1977 in forum Pool Equipment & Operations
    Last Post: 07-01-2013, 08:49 PM
  2. Pump Electric Advice
    By pratzert in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2010, 04:00 PM
  3. New Pool Electric
    By borderline in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2006, 08:52 PM
  4. gas vs. electric heater?
    By rlp in forum Pool Equipment & Operations
    Last Post: 04-14-2006, 09:41 PM
