Results 1 to 10 of 11
Thread: algaecide
    vinper is offline Subscriber Thread Analyst vinper 0
    Jul 2010
    Texas
    Default algaecide
    recently i used some big box algaecide , since then right after i add bleach or shock clear water turns green
    California
    Default Re: algaecide
    The algaecide probably had copper in it. Though copper kills algae, it can also turn water green, stain pool surfaces, and tint hair greenish as well. What was the specific manufacturer and brand of the algaecide?
    15.5'x32' rectangle 16K gal IG concrete pool; 12.5% chlorinating liquid by hand; Jandy CL340 cartridge filter; Pentair Intelliflo VF pump; 8hrs; Taylor K-2006 and TFTestkits TF-100; utility water; summer: automatic; winter: automatic; ; PF:7.5
    Jul 2010
    Texas
    Gonna look at it today , put it in for the winter . will have the water tested today at leslies
    Jul 2010
    Texas
    HTH yes it contains copper ,
    Jul 2010
    Texas
    My water turns green for a few days after shocking it with bleach . I am assumming its copper from some winter algecide . I ordered a culator
    California
    Yes, turning green after adding a lot of chlorine is the copper. It's mostly from the rise in pH upon chlorine addition. As the pH drops back down, the green may fade. We've had mixed reviews with the CuLator -- it works for some but not for everyone -- so be sure and report back what happens in your pool. We don't have enough reports to be definitive about that product.
    Jul 2010
    Texas
    Yes it bothers my wife. I assumed it would subside by swim time
    Jul 2010
    Texas
    culator has not change to any color , does not seem to have absorbed any metals running it 2hrs a day for last 2 weeks
    California
    It doesn't always change visibly on the outside. If you have a metal test kit you can see it the concentration in the water has dropped. Eventually, you can take the CuLator out to replace with another and can open up the old one to see if anything is visible. Or contact the company to see what they think.
    Jul 2010
    Texas
    well the water no longer turn green when i shock it . culator did not change color but i assume it worked
  1. Use of algaecide
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2013, 05:33 PM
  2. Is any Algaecide better than nothing?
    By NullQwerty in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-16-2006, 09:17 PM
  3. Algaecide
    By MartyW in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-20-2006, 11:41 PM
  4. Can anyone tell about HTH Algaecide
    By poolboyforjenny in forum Dealing with Algae & Slime
    Last Post: 08-21-2006, 07:25 PM
  5. algaecide overdosage
    By lmheid in forum Dealing with Algae & Slime
    Last Post: 05-21-2006, 02:46 PM
