Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 50 of 50
Thread: My Green Pool Saga - Help!
  1. #41
    Pamsel is offline Registered+ Thread Analyst Pamsel 0
    Central Illinois
    Default Re: My Green Pool Saga - Help!
    Ok, will just keep working on the chlorine, brush and vacuum for now. Will post an update tomorrow. Thanks!
    Pam, Illinois
    "17'x33' oval 14.5K gal IG vinyl pool; liquid chlorine; Hayward Pro Series, M-S-244T sand filter; A.O. Smith Centurian, Switchless, 1.40 HP pump; Right now 24/7hrs; Pool Solutions PS234
    Serial #6511, Drops / Powder; Community well; summer: none; winter: mesh; ; PF:8.3"
  2. #42
    Central Illinois
    Well, here is my morning update:
    CL 10-12 (since I am doing the dilution method it's hard to tell exactly)
    PH 8.0
    TA 330-350 (depends on if I stop when it first turns pink or when it's red)
    Pool water still unchanged in appearance...dark green and cloudy.
    At 10:00 last night I brushed the whole pool again, and added 5 gal CL
    I don't seem to be making much progress.
    Since I have no CYA reading, I got granulated cyanuric acid last night and put some in an old knee-high and hung it in front of my return jet this morning. It's rapidly washing it out of the sock, into the pool. I hope it's not going in too fast. Someone in an earlier post suggested I do this. Is this likely to help hold my CL level, if I get some stabilizer in there?
    Am I missing something? Maybe I need to be holding my CL level at 15-20 instead of 10? I would have expected my water to be clearing by now. Also, I'm wondering how I am to keep the CL level maintained at 10 when I should only add CL in the evening. Is it not correct that to add it during the day when the sun is shining is basicly to waste it? I have been adding during the day, but it is very sunny today, so I didn't add today. My last check of CL (mid-day) was 8.0.
    Pam, Illinois
  3. #43
    Quote Originally Posted by Pamsel
    PH 8.0
    Test is done when it turns red. Add one more drop and if there is no more color change then don't count the last drop.
    hope this helps
  4. #44
    Central Illinois
    That does help Evan. Though, if that is the case, my TA is higher than I thought it was. I have been stopping when it first turns from green to pink.
    I will retest this afternoon so I know what the correct reading is.
    Still no change in my water. One thing I've noticed is that there doesn't seem to be much settling out on the bottom and sides of the pool . . . seems to be in suspension. I have in the past used a chemical from the pool store (I don't know what it was, except that the name is phlox) that pulled the stuff out of the water and dropped everything to the bottom of the pool. Then I swept it to waste. That was the only thing that cleared my water last year. I'm wondering if I need to use something like that again. The chlorine alone doesn't seem to be making a dent in it...unless I just need to add much more chlorine than I have been??
    Pam, Illinois
  5. #45
    The cloudiness is dead algae. The filter should take care of it but it can take some time. Floc (correct spelling) or flocculant is what you used before. Sometimes it can be helpful. Also, a clarifier can cause the dead algae to clump into larger paritcles that your filter can remover more effeciently. Be aware that using either of these types of products can introduce their own problems (uaually very small). If the pool has no more green and the filter has not taken care of the cloudiness in a few days of constant running then you might want to try either one or the other. Clarifiers are better if the water is only slightly cloudy. If there is a lot of stull suspended in the water then a floccuant is a better choice. If you have not killed all the algae yet then you just need to keep up with the chlorine and THEN worry about getting it clear. It usually clears up on it's own once the algae is gone.
    Hope this helps
  6. #46
    Central Illinois
    Thank you Evan, that does help. Everything you explain helps me learn more about what I'm doing. The water is still green, as well as cloudy so I guess I will keep working on the algae with the chlorine. So far I have put 33.6 gallons of CL in since Tuesday noon and there is very little noticable difference, but this afternoon both my husband and I think the green is a lighter shade and I can now see the bottom step clearly where before I could only see the first two steps. So, it appears that something good is finally starting to happen!
    Pam, Illinois
  7. #47
    Maine, USA
    Well, I tried to PM back to you, but of course there's a 2 private message limit ( which is really unmanageable I don't get it ).
    Anyway, there's a lot going on in this thread and I don't see much talk (on your end) about your filtration (could of missed it). What kind of filter do you have? Are you able to backwash at all (and have you been backwashing constantly?). I have a DE filter and when I opened my pool, THIS was more than half the battle. When the filter was doing its job, I had to backwash about every 3-4 hours or so for the first couple of days. I like taking my filter apart once or twice in the process as well to hose it off. I just haven't seen anything that you posted saying that you're doing this with "the process". Besides all the expert advice that you're receiving to get your chemical balance in line, I would also concentrate on the filter area
    Regards,
    Ron [ muvipix.com ]
  8. #48
    Quote Originally Posted by rhosk
    If you become a subscriber to the forum your PM message limit will increase!
    http://www.poolforum.com/pf2/showthread.php?t=219
  9. #49
    Maine, USA
    Hi Evan,
    I purchased a testkit (qualifies for 1 year subscription?), PM'd PoolDoc twice in last month to change my status - nothing. And, needless to say, I had to delete those 2 PM's to PM again
    Frustrating...
    ps, sorry Pam for Off Topic posts.
    Regards,
    Ron [ muvipix.com ]
  10. #50
    Central Illinois
    I have a sand filter with new sand last summer. I've had it running 24/7 almost since I opened the pool mid-April. The only times I've had it off was when I was told to let the stuff settle out for a couple of days about 2 weeks ago. I have been backwashing 3-4 times a day since I started this process from this forum last Tuesday. Before that, I backwashed once a day.
    New twist ~ I have to leave today for a funeral in Indiana. Won't be back until tomorrow night. Not a good time to leave the pool unattended. I will leave the filter running and backwash before I leave. What else to do??
    Test results this morning:
    CL 16
    PH 8.0
    TA 340
    CYA 25
    Looks like my CL is a little high now, although in re-reading all the posts this morning, I see that Evan's last suggestion was to keep it at 15, so maybe this is ok. Today is the first day I've had a CYA reading. Water color unchanged, but more cloudy this morning - perhaps because I brushed the pool again late last night?
    Pam, Illinois
  1. The saga of cracked pool.
    By Amir in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2007, 06:42 PM
  2. Dolphin climbing saga....
    By scott747 in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-25-2007, 10:42 AM
  3. My suction side leak Saga
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 08-24-2006, 05:57 PM
  4. New Pool start-up saga...
    By Maxout in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 02:08 PM
  5. Ben's Test Kit saga
    By Bleach=Chlorine? in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2006, 03:08 PM
