Results 1 to 10 of 50
Thread: My Green Pool Saga - Help!
    Pamsel is offline Registered+ Thread Analyst Pamsel 0
    Central Illinois
    Default Re: My Green Pool Saga - Help!
    Sherra, thank you so much for your reply. Can you please tell me what CYA is? I don't have it on the test strip. I will go get a drop kit today and the acid and chlorox.
    BTW, When I take my water to the pool supply store to have it tested, all they do it stick the same test strip in it that I have at home. They don't tell me anything more than I already knew.
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    CYA is cyanuric acid/stabilizer/conditioner. 99% of the "pucks" or "sticks" you get now a days have CYA in them (if the ingredient starts with "trichlor", then they've got CYA added to them). TOO much CYA can become a very serious pain in the you-know-what when it comes to keeping your pool sparkling clean. You do need SOME CYA in your pool though to keep the chlorine from getting "eatten up" by the sun during the day. If your pool store uses the strips, fire the pool store...find another one. You need to look for a drop based test kit that tests for the following:
    FC - Free Chlorine
    CC - Combined Chlorine
    It's best to have both the drop based kit (OTO) and the (DPD-FAS) powder test - the DPD-FAS tests will test up to about 50 PPM for chlorine, which is what you'll need to test accurately for your "shock" levels.
    TA - Total Alkalinity
    CA - Calcium Hardness
    pH - pH (phenol red drop based test)
    CYA - Cyanuric Acid/Stabilizer
    If your pool store doesn't carry the kits that test all that, sometimes Wal-Mart will carry tests that test all those things, if you've got an ACE Hardware around sometimes they will carry them also. Other than the test kit Ben sells on the Poolsolutions web site (sister site to this forum), the next best is the Taylor K2006.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Central Illinois
    Another thing, in reading the link on lowering Alkalinity, he speaks of aerating the pool as a part of the process. What do I do if I don't have an aerator of any kind and it's not ready to put 10 year old boys in yet? Will the process not work if I don't aerate?
    The aeration is what allows the carbon dioxide to be off-gassed, so it is an important part of the process. You can get a cheapie fountain in the pool section at almost any store that would work fine. You also can achieve a similar effect by aiming your return eyes toward the surface of the water so that it creates a ripple from your return jets.
    Before you shock your pool, we really need to know if there is any metal content (copper/iron?) in your water, and what type of finish you have. Otherwise, Sherra's got you on the right track.
    Central Illinois
    Hi Janet,
    It is a vinyl lined pool.
    How do I know if I have copper, etc? The water in our area has a lot of iron in it - it has been a problem in the past, as in when we add water it comes from the hose into the pool yellow/brown and turns the entire pool a greenish yellow. It has been helped a lot by adding water via putting the hose in the skimmer and having it go through the filter first. It would be a good guess that we have metal content in the pool, especially since I have added water several times with the garden hose, due to vacuuming to waste and lowering the water level.
    The iron content is what I was getting at. My understanding is that you need to put a metal sequestering agent into the pool before you shock it, to keep it from staining. Also, adding water via the skimmer does help too. Search through the forums for posts by mbar--she's our resident metals/staining expert around here, and she may be able to help you get it cleared up without staining your pool.
    Central Illinois
    I think that may be why the pool store told me to use "Stain Ban" first thing in the spring. I do have some of that on hand, if needed. I will try to find mbar - Thank you!
  1. The saga of cracked pool.
    By Amir in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2007, 06:42 PM
  2. Dolphin climbing saga....
    By scott747 in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-25-2007, 10:42 AM
  3. My suction side leak Saga
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 08-24-2006, 05:57 PM
  4. New Pool start-up saga...
    By Maxout in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 02:08 PM
  5. Ben's Test Kit saga
    By Bleach=Chlorine? in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2006, 03:08 PM
