Results 1 to 10 of 10
Thread: Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    mas985's Avatar
    Pleasanton, CA
    Default Re: Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    First, you really don't need total head to size a pump. What drives the pump size is the flow rates requirement for things other than the pool itself. Examples, are spa jets and waterfalls. If the pool is the only consideration, you can go as small as you want. But if you are interested in doing the calculations, I have a few tools in the link in my sig labeled "Energy Efficient Swimming Pools".
    Since you have a water feature, downsizing the pump will affect the look of the waterfall. But since you have the valve half open, I guess that is not really a problem either.
    But one thing to consider is that the Superpump line is a great pump and they are all up rated and a little smaller than the label would indicate. So you have a 1.5 HP up rated pump that is similar in strength to a 3/4 HP full rated pump like a Super II or Tri-Star or Whisperflo. The Superpumps tend to be smaller pumps than a standard pump which is good news because that means it will use less energy than a typical 3/4 HP full rated pump.
    If the only issue is that you have to switch the wires to go from high speed to low speed, I would keep your old pump and just get a two speed timer.
    http://www.amazon.com/Intermatic-PE1...wo+speed+timer
    Mark
    May 2010
    I'm sorry to be so slow in acknowledging your response. I didn't get an e-mail notification of the response (not sure if this site does that), and I just wandered back to this post as I'm ramping up to start attacking this issue.
    I lucked into a flowmeter at a good price, and I'll be installing it in the next few days. That will give me an idea of existing flow rates, high/low, with/without heat pump. I'll probably go ahead and calculate the head. It will also take me several days to digest all the good information on your Energy Efficient Swimming Pools site.
    If anything challenging comes out of this additional research, I'll post again to this thread.
    Thanks!
    15K gal IG pool; 13 yr old 2spd 1.5HP Hayward SuperPump w/ rebuild motor; 24" Tagelus TA-60 filter w/ zeolite media ; heat pump; chlorinator.
    Pump located ~4 ft abv water level; water features ~3 ft above water level; all plumbing 1.5"
    mas985's Avatar
    Pleasanton, CA
    Let me know if you need any help but have you considered downsizing just the impeller? It is fairly easy and cheap to do and it effectively makes the pump "smaller". You can keep the old motor.
    Mark
    Since when is the Superpump an up-rated series? I thought it was full-rated as most IG pumps are.
    mas985's Avatar
    Pleasanton, CA
    I believe Superpumps have always been up rated as far as I know. And the split between up rated and full rated for in-ground pools is about 50/50. Nearly every IG pump line has an up rated version and some pump lines have only up rated versions. Few pump lines, if any, have only full rated so the full rated versions are probably more rare although I think I see about 50/50 on the forums.
    Also, AG pools are nearly always up rated and sometimes double up rated.
    Mark
    May 2010
    Would downsizing the impeller reduce the motor's current draw or just reduce the flow? If there is a reduction in current draw, would it be proportional to the reduction in flow? Would this reduce the flow at low speed below what is usable/worthwhile? (Repeat note - I'll be installing a flow meter in a few days.)
    mas985's Avatar
    Pleasanton, CA
    A reduction in the impeller size reduces both the flow rate and motor's energy consumption. The impeller is the load for the motor. A smaller impeller is a smaller load so the motor does not need as much energy to spin the impeller and energy consumption drops. The energy factor as measured by gallons pumped per watt-hr consumed is higher with a smaller impeller so the energy efficiency is better. So yes, a smaller impeller is worth it especially since it costs much much less than a new pump. Usually the impeller and seal can be had for less than $50.
    http://www.amazon.com/Hayward-Series.../dp/B0037V0S3S
    I hate to sound like a broken record but your current flow rate is irrelevant. If you are interested in reducing energy consumption all you need is a smaller impeller and/or pump. A two speed motor just adds another level of energy efficiency.
    BTW, I kind of lost track of what your primary objective. I know you are having issues with the system but can you recap what your objective is with this whole thing?
    Mark
    May 2010
    I'm finally back to this thread. Had a fun few weeks with a stain treatment and other get-ready-for-summer games.
    My goal is to see if there is/are modification(s) to my system that will reduce electricity consumption with no more than a 2 to 3 year payback while maintaining sanitation, clarity, water feature functionality, etc.
    I just got the flowmeter installed. Readings are:
    ** Pump on high speed, heat pump bypassed (winter) - 60 gpm, 4.2 hours/turn
    ** Pump on high speed, heat pump in circuit (summer) - 40 gpm, 6.25 hours/turn
    ** Pump on low speed, heat pump bypassed (winter) - 20 gpm, 12.5 hours/turn
    ** Pump on low speed, heat pump in circuit (summer) - too low to measure, below 20 gpm
    An updated list of options that I can think of or that were suggested is:
    ** Keep existing pump and continue to swap wires with the seasons
    ** Keep existing pump, downsize impeller and continue to swap wires with the seasons
    ** Add a 2-speed pump timer to the existing (or new) 2-speed pump. Run at high speed during swimming season for filtration/heater/water feature/chlorinator. Run at low speed during swimming season for filtration/heater (chlorinator won't work). Run at low speed during winter for filtration/water feature/chlorinator.
    ** Replace pump with a variable speed/variable flow model. (Even with the 1.5 HP Hayward Super Pump VS and Max-Flo VS models that are designed for 1.5 inch piping, this is probably not cost effective with electricity costing approximately $0.10/kWh before taxes and fees.)
    ** Replace pump motor with a variable speed unit. (Also probably not cost effective.)
    ** Replace pump motor (and impeller) with a 1 HP, 2-speed unit and continue to swap wires with the seasons (or add two-speed timer).
    ** Replace pump motor (and impeller) with a single-speed unit.
    Based on the current flow readings, would a downsized impeller reduce the flow to where I wouldn't get enough turns and/or (in summer, with a two-speed pump timer) the heat pump would not come on at low speed? In winter, at low speed could I end up with not enough flow/pressure to operate the chlorinator and/or water feature?
    Thanks again.
    mas985's Avatar
    Pleasanton, CA
    First, # of turns really doesn't mean much. Just run the pump for as long as necessary to remove the debris out of the pool and to add sufficient chlorine. Those are the only things that matter. Usually a pool can get clean in as little as 3 hours independent of flow rate and turnover. The biggest energy saver can be to simply reduce run time.
    Next biggest reduction in energy consumption comes from running on low speed. Generally, that will save 50% in energy costs with doubling of run time. But sometimes you don't need to double run time so you can save even more. Water features might be an issue but why run them unless you are using the pool. The chlorinator should not be an issue although you may need to make some adjustments. The heat pump may or may not work on low speed but you can try it can't you?
    A VS improves energy efficiency slightly more but usually it is not enough to justify the extra cost of the pump.
    It think you should either get a toggle switch for the pump or a two speed timer. That is all you really need.
    Mark
