Re: Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
Would downsizing the impeller reduce the motor's current draw or just reduce the flow? If there is a reduction in current draw, would it be proportional to the reduction in flow? Would this reduce the flow at low speed below what is usable/worthwhile? (Repeat note - I'll be installing a flow meter in a few days.)
15K gal IG pool; 13 yr old 2spd 1.5HP Hayward SuperPump w/ rebuild motor; 24" Tagelus TA-60 filter w/ zeolite media ; heat pump; chlorinator.
Pump located ~4 ft abv water level; water features ~3 ft above water level; all plumbing 1.5"
