Thread: Oval Install Question
    Jul 2012
    Kentucky
    Default Oval Install Question
    I am getting ready to install a 15'x30' oval pool with buttresses. I talked to some installers and they said they would level the ground and add several inches of sand and then bury the buttresses in the sand. The directions say to bury buttresses in dirt then add sand to level inside. Does it matter which way this is done?
    BigDave's Avatar
    Default Re: Oval Install Question
    It does matter. As I understand it (I'm not a pool installer) the pool's structure must be built on level compacted soil. Sand can easily wash away and if the pool structure sits on sand it could fail in a heavy rainstorm.
  1. I have an oval install ?
    By Markin Fuquay in forum Above-Ground Pool Construction & Repair
    Last Post: 07-29-2011, 10:22 AM
  2. Question about beaded liner install
    By denanbob in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2006, 09:28 PM
  3. Question About AG Install
    By glepage in forum Above-Ground Pool Construction & Repair
    Last Post: 06-07-2006, 07:53 AM
  4. AG Pool Install Question
    Last Post: 05-26-2006, 09:04 PM
  5. Oval install & owner horror stories true?
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 04-27-2006, 12:12 PM
