Scaling on cell...why?
Since 2004 I've never had an issue with scaling on the cell, an Aqua Rite T-15 cell (we're on our second cell). Last fall when I closed, I notice quite a bit of hard white deposits on the cell. I cleaned it out using water pressure from the hose nozzle and some scraping with a wooden toothpick. I didn't want to use acid as I've read it will reduce the life of the cell.
There's a few changes I made last season based on advice here and wonder if any may caused the scaling.
1. Based on advice here, I stopped adding acid every time the pH reached 7.6 - 7.7. I was told as long as it didn't go above 7.8, then it was fine. Since my pool seemed to stabilize at about 7.7, this meant I rarely had to add acid last season.
2. I use to add a maintenance dose of Jack's Magic Purple Stuff each week because of a metal staining issue in 2006 or 2007. The product states it also helps protect the cell from scaling. Last season I did the bucket test for metals and it came up negative, so I was told here I could probably stop using the Purple Stuff. I was hesitant to quit all together (really don't want to deal with metal staining again..what a costly pain in the neck!), so I just added half the normal dose each week (no metal staining occurred).
3. I use to shock on a regular schedule, every two weeks, with cal hypo. I was told here that I only needed to shock if CC got above .5. Since I make an effort to maintain proper CL levels per Ben's best guess chart, I rarely had to shock last season. Btw, even shocking every two weeks with cal hypo, my calcium level didn't get above 260 (typically it runs from 220 to 250).
For reference, here are the levels I maintain throughout the season.
FC 5
CC < .5 (usually 0)
pH 7.6 - 7.7
TA 80 - 100
CYA 70 - 80
Borates 50 - 60
Salt 2800 - 3200 (as recommended by Aqua Rite)
Calcium typically 220 - 250, but I expect this will drop this season since I haven't added calcium since 2011 and I stopped shocking on a schedule with cal hypo. This season I plan to just use plain bleach.
I also ad 4oz of polyquat each week as insurance against algae (I may try without this season).
Any ideas if any of the above changes contributed to the scaling?
Thanks.
