Re: Open Pool, Shocked But No Chlorine Level
I have two of the best kinds of test strips you can get as a pool owner, and they are fresh this season.
I also have PoolDoc's PS232 and PS233 kits. I have the WalMart HTH 5-way kit, and Leslie's FAS-DPD test kit (made by Taylor) AND Leslie's full test kit for all the other tests (again, made by Taylor).
I can flat-out state categorically, that there is NO WAY these strips compare in accuracy or reliability to the drop kits. These new strips are now good enough to give a reasonable BALL-PARK view of the water--but no more.
This is a huge improvement. Previous strips have ONLY been able to say if I have lots of chlorine, or little to none--no more.
Greg, I have no idea what you are basing your statement on. Certainly it cannot be from day-to-day comparisons, like I have made over the last 7 years.
I have found LOTS of pool stores using and pushing strips for one reason, and one reason only--they are EASY TO USE--apparently. Oh--and they are expensive, too. But that is deceptive. You have to use them and read them VERY carefully. And most importantly, you have to be VERY skeptical of them and know when the SLIGHTEST thing off means you cannot trust it.
I can and do use strips--I'd rather not but with two kids and school, I'm lucky some days to have the 30 seconds for a strip, much less the 2-5 minutes I need for drop-testing--which I ALWAYS prefer.
If you use strips, use them wisely. Be skeptical of them. And do NOT use them instead of drop testing.
