Thread: Solar Covers and Safety
    Default Re: Solar Covers and Safety
    Solar blankets are NOT safe; there's a well-known scene in one of the early Lethal Weapon movies that illustrates the problem, albeit in somewhat exaggerated form. Here's the YouTube from Warner Brothers: https://www.youtube.com/watch?v=DndZsC25noQ
    The closest thing to a 'safe' solar blanket would be an automatic pool cover with translucent fabric for the cover.
    Jun 2011
    Well the auto pool cover isn't going to happen. I just don't have the funds for it, plus I could imagine that people would be stunning their toes all day on the rails.
    What if you cut you solar cover in strips? This way you could fall between the strips and have a much better chance at being able to come up for air. How about attaching floating strips of foam legthwise along the cover so that it is less likely to "engulph" you.
    Liquid blankets? Homemade solar rings?
    BTW, I can't believe someone hasnt invented a safer method yet.
    BigDave's Avatar
    Alisonquilts here, on the forum has already made her own solar rings.
    Watermom has had success cutting her solar cover into pieces. In her case to ease installation / removal but would reduce the chance for entanglement.
    I do not believe that liquid solar covers would be much help - at best it might reduce some evaporation on a windless night at the cost of dumping mystery goo into your pool.
    Please remember that pools are NOT safe. Admittedly, adding a solar cover may add to the risk but the primary mitigation must be protecting the perimeter - excluding all people or animals that could end up in the pool when they shouldn't. That said, mitigating the secondary risk doesn't hurt.
