Thread: Solar Covers and Safety
    Jun 2011
    Default Re: Solar Covers and Safety
    Well the auto pool cover isn't going to happen. I just don't have the funds for it, plus I could imagine that people would be stunning their toes all day on the rails.
    What if you cut you solar cover in strips? This way you could fall between the strips and have a much better chance at being able to come up for air. How about attaching floating strips of foam legthwise along the cover so that it is less likely to "engulph" you.
    Liquid blankets? Homemade solar rings?
    BTW, I can't believe someone hasnt invented a safer method yet.
    BigDave's Avatar
    Alisonquilts here, on the forum has already made her own solar rings.
    Watermom has had success cutting her solar cover into pieces. In her case to ease installation / removal but would reduce the chance for entanglement.
    I do not believe that liquid solar covers would be much help - at best it might reduce some evaporation on a windless night at the cost of dumping mystery goo into your pool.
    Please remember that pools are NOT safe. Admittedly, adding a solar cover may add to the risk but the primary mitigation must be protecting the perimeter - excluding all people or animals that could end up in the pool when they shouldn't. That said, mitigating the secondary risk doesn't hurt.
