Thread: Old Liner bit the dust
    Jul 2012
    Mexico, Missouri
    Default Re: Old Liner bit the dust
    Most new Intex pool are shipped with a through the wall skimmer/filter/pump with only one outlet hose. Check Amazon.com and eBay for the fittings for your 2500gph pump. each fitting will be about $16 usd, and valves are sold separate.
    Edit:
    Just looked on Amazon again, here are links to the sets:
    Intex Pool Plunger Valve with Strainer Assembly
    Intex Plunger Valve with Hose Connection
    Last edited by PoolDoc; 04-14-2013 at 08:52 AM. Reason: fix Amazon links to use item description, and to support PoolForum.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
