Results 1 to 9 of 9
Thread: Phosphates? High CYA!
    Largo, Florida
    Default Re: Phosphates? High CYA!
    In 13k gallons of water, 1 gallon of 6% bleach will give you 4.75ppm. So if your bottle = 1 gallon, 1/2 of that bottle gives you about 2.4ppm. At 90cya you need to be over 20ppm to shock.
    This is based on the best guess chart and your 90ppm cya. You need to KEEP it above 20ppm and keep testing for combined chlorine until your CC is 0, and you don't lose more than 1ppm FC between sundown one night and sunup the next morning.
    Once that happens you can let it drift down to 5-10ppm for regular operations. I keep my pool at that level of CYA (because my swcg recommends that level) so you can definitely run your pool at 90ppm cya.
    If you're not diligent enough to maintain things on a regular basis - and don't have a metal pool - then you might want to consider a salt water chlorine generator. You still have to stay on top of your pH (I usually dose with acid about once a week). A swcg won't help you clean up the mess though; you're going to have to do that the regular way.
    onemsmom is offline PF Supporter Thread Analyst onemsmom 0
    Aug 2010
    Thank you so much!
    Aug 2010
    Question - would adding extra bleach buy me more time between checking/adding or make this process go more quickly or would it just waste bleach? Ex. if I'm supposed to keep the level above 20, would it speed things up to keep it above 30, etc.?
    Thanks,
    Jennifer
    For shocking, a higher FC level makes things go somewhat faster but the chlorine losses from sunlight are greater since they are based on the percentage of FC. However, speeding up the algae kill isn't the slowest part of the process. The slowest part is then removing the dead algae via filtration.
    As for regular maintenance, starting with a higher FC level will have it last longer, but because it drops as a percentage of FC you will be using more bleach. It's not "wasteful" so much as a trade-off between convenience of not adding chlorine as often vs. the extra cost associated with the larger amount of bleach that is needed.
