Re: Visalia 25k Gallon Filling Now
I like starting new water with dichlor, it dissolves quickly and adds 9ppm CYA for every 10ppm FC. It's also helps lower pH which your water needs. 25lbs of dichlor should get 25000 gallons of water to 60ppm CYA - a bit higher than we usually recommend but higher CYA can help mitigate FC loss due to heat and sun (is it sunny on your pool?).
Just use dichlor to chlorinate the pool - following Ben's Best Guess Chart until you've used up all 25 lbs then your CYA should be 60. Perhaps you should take a CYA measurement after adding 15 lbs (should be 36ppm CYA) to be sure we're not way off. Every pound of dichlor should add about 2.7ppm FC - use that as a guide to chlorinating. Don't forget to increase your target FC as the CYA builds (12ppm CYA for every 5lbs dichlor).
Be cautious when buying dichlor - many retailers add copper, detergent, other junk that you do not want fouling the new water. Sam's club may have pure dichlor (99% dichloro....). Wall mart probably doesn't. If you search around the forum, you'll find alot of disussion about adulterated dichlor and links to Amazon source of the good stuff. Leslie's also sells pure dichlor (last time I checked) but it's pricey.
While maintaining normal FC levels with dichlor you will be able to adjust TA and pH.
When the CYA goal is reached, start chloinating with CalHypo or bleach (liquid chlorine). Don't let the undissolved dichlor come into direct contact with any form of hypochlorite - things can go boom.
