Spring Start U
Is there a "sticky" or thread that talks about the steps to starting up a pool? We didn't cover this past winter and our pool is very green. We just got the pump/filter hooked back up and running. I don't have any levels yet, but I just wanted to do some reading and figure out what I need to do and in what order. What levels do I need to work on first: pH, chlorine, CYA? I wanted to check on here first before I started dumping in any borax or bleach. Thanks for the help.
Jennifer
Re: Spring Start U
Yup. Go to our sister site, Poolsolutions.com and start reading. We should have stickied posts here as well under the various forums.
