Thread: Where do I buy Phoshonic Acid - and do I need it?
    Default Re: Where do I buy Phoshonic Acid - and do I need it?
    usually yes but small ones. The ones I have used have always lowered my pH. Nothing a bit of borax can't fix! Some products want your pH or other paramters in a certain range before you use them. Just follow the directions and you should be ok. If you KNOW there is iron in your water they are a MUST if you don't want stains in your pool.
    Hello,
    Luke the semi-professional pool guy here. As regards to Jack's Magic, I do use their products regularly for stain removal. The purple stuff is correct for salt water pools. Blue stuff for chlorine pools. The stuff does work. But once you are on the product, you have to continue using it to keep the stains away. Most of my clients spend about $300-$400 for stain removal than $40 or so a month keeping the stain away.
    Jack's Magic is the best in stain removal technologies. I love them, expensive, but good.
    Luke
    ps... jack's stain products will lower the ph, but not purple or blue stuff.
  1. Where to buy CYA? & acid ?
    By PJM361 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 01:13 AM
  2. Dry acid vs Muratic acid
    By jackinlv in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-25-2011, 01:44 PM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  4. Too much acid?
    By k2vell in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2006, 10:57 PM
  5. Dry acid versus muratic acid - and how to add?
    By west1745 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2006, 01:19 AM
