Re: My start up Numbers
New numbers
FC=9.8
CC=0.4
CYA=56
PH=7.4
These are close but not exact to your recommendations Dave. The ambient temp is going to keep us out of the pool for probably better than a month. Should I keep trying to fine tune these numbers? Or let them ride for a bit? I do want to put the solar cover on as soon as I can to reduce delay's when the warm weather hits.
For some unknown reason. I end up testing PH twice. The first reading is almost always low around 7.0. The second reading is typically around 7.4 or slightly higher.
24 round 12.9K* gal AG vinyl pool; liquide chlorine; sand filter; 2 1 speed pump; 8 hrs; ; the recommended Taylor kit; utility water; summer: solar; winter: mesh; android phone; PF:9.3
