Results 1 to 10 of 15
Thread: If this was your fill water, what would you do?
    Bosch232 is offline Registered+ Thread Analyst Bosch232 0
    Aug 2012
    Nebraska
    Default Re: If this was your fill water, what would you do?
    Well I filled the pool 5 days ago, and I've successfully gone from TA = 300+ to TA = 100 and pH of 7.4 as of tonight. It required gradually adding 3 1/2 gallons of muriatic acid and aerating 24-7 for 5 days straight. But I'm there.
    Does TA change a whole lot week-to-week, or should it be pretty stable now?
    16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
    BigDave's Avatar
    Congrats, sounds like your fill and startup went well.
    TA shouldn't move a whole lot but what's "normal" will be uniquely "normal" for your pool. Keep an eye on TA and pH stability for a while to get a feel for what's normal for your pool. A TA about 80 may be ideal for bleach chlorinated pools but if pH stays stable, 100 should be just fine.
    Aug 2012
    Nebraska
    Here is graphical data of my weeks activity.
    BigDave's Avatar
    Nice recordkeeping! What kind of chlorine are you adding? How did you add the CYA?
    Aug 2012
    Nebraska
    Chlorine and CYA are just HTH from Wal Mart. Granular versions of both.
    I'm a bit uncertain about the CYA, because I added 2 lbs and the test still says ZERO.
    So I'm not quite sure I've got that dialed in.
    Aug 2012
    Nebraska
    I didn't exactly answer your question.. I've added both to the skimmer, slowly pouring it in.
    BigDave's Avatar
    CYA can take a long time to dissolve - don't bother testing for 4-5 days after adding granular CYA.
    There are a couple types of powder chlorine - most likely Dichlor or Cal-hypo. Dichlor adds CYA, Cal-hypo doesn't. Either is OK right now as you need CYA but it's good to know what to expect. Which do you have?
