Results 1 to 10 of 10
Thread: Pump Motor: Repair or Replace?
    Default Re: Pump Motor: Repair or Replace?
    What a nightmare! I went to a company called wetheadpumprepair.com out of Rochester. Today, the parts I needed were supposed to show up, a used bell, four long bolts and the clip that holds the bell to the bearing. A bell came, used, in some of the roughest condition I have seen, and filthy. It's in a parts bath. But no bolts, no bearing clip...it's all of a sudden back-ordered. To reverse the order, I have to pay shipping to return the bell. So I cancelled the order, I'm stuck with having spent $65+ on bearings, seals, a used bell, all of which is now useless because the critical parts are....back-ordered--and no pump.
    So...I went back to my old standby, Leisure Living, aka poolsupplies.com and ordered a new Hayward 1hp 2 spd Superpump. I considered the Pentair but that was only about $60 cheaper...and now I have spares of just about everything. I should have the pump Monday and I'll try to keep my pool from turning green till then. This is one time that tri-chlor erosion pucks are worth their weight in gold!
    Also, I, personally, will never do business with WeT HeaD ever again. I cannot recommend them.
    BigDave's Avatar
    I'm so sorry you had such a bad time. Good luck with the new pump.
    Thanks, Dave. The new one should be an easy drop-in. I'll just put on the fittings and wire it up and be ready to go!
    The new pump arrived today! FedEx Ground left it by my garage and never even rang the bell, though I was home all day. I checked tracking around 5 and the person had left it with no notice several hours earlier...and nobody who went in or out of the garage mentioned it. ARGHHHH!
    But I got it installed and running, only one wrong connection that popped the breaker. Found it, fixed it, now it's running!
    Now I cannot get the SWCG to run properly....Sean, Please help! It powers up but says it can't communicate with the cell.
    If it's not one thing, it's another....
    Just an update: It was a setting and the SWCG has been running nicely. I'm slowly bringing the chlorine gen level down to try to get to match the ideal for the CYA (currently 60) but the FC today was 8.
    Meanwhile the new pump is silent and wonderful.
    I still need to fix the old one. Now the impeller is stripped and one of the switch blocks has a snapped-off mounting ear. But time has kept me from addressing these problems.
    I found my pH trending DOWN--surprise! So I added a very sophisticated combination of pH increaser and T/A increaser...Arm&Hammer Washing Soda!
  1. Replace motor or pump and motor?
    By myLABSpool in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 02:13 PM
  2. replace or repair damaged pump motor
    By hikernut in forum Pool Equipment & Operations
    Last Post: 10-04-2012, 05:43 PM
  3. Replace motor or motor& pump?
    By jtcaputo in forum Pool Equipment & Operations
    Last Post: 09-08-2012, 08:27 PM
  4. Pump started screeching - repair or replace?
    By aquarium in forum Pool Equipment & Operations
    Last Post: 10-29-2006, 10:45 AM
  5. What do I replace along with the pump motor?
    By deanbrew in forum Pool Equipment & Operations
    Last Post: 06-09-2006, 12:18 PM
