When I purchased my new home, it came with an 18' above ground pool with a Jacuzzi (I think) sand filter. The pool was winterized when I bought the house, the pump was stored in a shed.
I hooked up the pump, and opened and filled the pool. The water is crystal clear!
The filter has a gauge on it which reads 10 psi even when the pump is off. Is this normal or should it read zero?
The pressure goes to 22 psi when the pump is running in 'filter' mode. I am thinking the gauge is just shot.
Thanks!
