Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Thread: Pool is clear but bottom looks spotty and dirty
  1. #21
    BigDave's Avatar
    Default Re: Pool is clear but bottom looks spotty and dirty
    I'm sorry I can't give you a better plan, maybe some will read this who has another idea.
    How's the pool surface holding up to the scrubbing? How are your numbers holding?
    A couple warnings about algaecides:
    Some have copper - not something most that really belongs in a pool - It can stain the pool, fingernails and blond and colored hair.
    Some have ammonia which can combine with chlorine to form monochloramine ( an effective algaecide but stinky and irritating ) however a tremendous amount of chlorine will be consumed trying to overcome the ammonia and chloramines.
    Some have Trade Secret - I'd never put that in my pool.
  2. #22
    BigDave's Avatar
    Suggestions:
    • Get a K2006 kit.
    • Read the Best Guess Chlorine page.
    • Adjust your chlorine levels to the correct range for algae killing -- use the low end of that range.
    • Keep the chlorine there . . . for weeks.
    • Begin brushing REGULARLY.
    • Do not wear high-fashion expensive swimwear in the pool. Skin is VERY chlorine resistant; women's swimwear that costs over $100 is NOT. Such suits are made to be seen in, not to be swum in. If you use the pool a LOT, all polyester water aerobics suits are super-durable.
    Black algae penetrates down into the cracks and crannies of the pool surface. Even when it seems to be gone, it's not. If you keep brushing while maintaining chlorine levels, it will be *mostly* gone 2 weeks after you can't see it any more.
    But, it will not be all gone, and will recur if you let chlorine levels go low.
    Note that if you have stabilizer levels above 40 ppm, and do not READ and FOLLOW the Best Guess Chart, you're mostly wasting your time. Keep in mind that test strips are HORRENDOUSLY inaccurate when use to measure stabilizer.
    I just saw that Ben had provided this advice to someone asking about Black algae. Perhaps we didn't need to go to +shock+ level but other than that we're consistent.
    Please resist the urge to "throw stuff at it". Doing so will most likely make it much harder to clean.
  3. #23
    rkrgk is offline Subscriber Thread Analyst rkrgk 0
    May 2012
    Phoenix, AZ
    Thanks BigDave for sending me the post from Ben.
    My problem is that the remianing algae does not come off the pool surface at all. I was hoping there is an easier way to make chlorine reach these pores so that there will be progress when I scrub next time.
    As I mentioned I did make lot of progress, whatever I could remove with my brush I removed them. And my numbers are not looking that bad (dont know why I dont use much Chlorine overnight with some black algae present still).
    This is what I got yesterday evening and this morn.
    FC - 8.5 (no change from last night)
    pH - 7.8
    TA - 150
    CH - 400
    CYA - 40ppm
    Borate - 30ppm
    As you can see I also added some Borax thinking it might help me control algae in the long term. I am ading some pics with this. Some of the spots that you see in the pic could be the shadow not the black spots. As you can see the walls and bottom are pretty clear of algae, but there still some.
    18x32 kidney 15K gal IG Gunite pool; skimmer tabs; Hayward DE6000 DE filter; Hayward/AO Smith Superflow 1 speed pump; 12 hrs; heat pump, fountain or waterfall; Taylor K2006C ; utility water; summer: none; winter: none; android tablet; PF:8
  4. #24
    BigDave's Avatar
    It makes sense that the overnight FC wouldn't change much with so little of the algae's surface area left exposed to chlorine.
    I think Borate is a good choice - maybe a little higher. The pH might be getting a tad high (especially with 400 CH). Muriatic Acid is a good way to bring it back down - Be sure to read and understand:Using Muriatic Acid to Safely Lower Your Pool's pH.
  5. #25
    May 2012
    Phoenix, AZ
    Yeah, I was following PoolDocs writeup on increasing to 50ppm, I got only 5 boxes of borax last time, I am planning to add 5 more, thats the reason my pH was a little off too.
    I did reduce the pH to 7.4 in the last two days.
    I also got the polyquat 60 from amazon. And planning to add and see if it makes any difference. and may be get some trichlor powder and sprinkle directly on top of the black spots and brush if I can.
  6. #26
    BigDave's Avatar
    Sounds like a pretty goo idea - it will lower the pH locally so be on the lookout for pitting in the plaster.
    One method I've read is to put the chemical in a zip-loc bag to transport it to the stain then pour / squeeze the slurry onto the target spots.
  7. #27
    May 2012
    Phoenix, AZ
    Good point,yeah I somehow thought Trichlor is basic, when you mentioned I checked the Taylor booklet,its pH is 2.8-3.5. Hopefully wont stain, I guess I need to take a chance *rock and a hard place*.
    Sounds like a good idea. Let me go check if I can get some Trichlor powder locally here. I have the pucks from last year, but dont have a holder (like this, but got bad reviews.. http://www.amazon.com/Pentair-542068...pentair+holder) or else I could just use it to scratch the floor with it to get same effect I guess. shallow ends I could srub with the puck and see if it makes any difference. I will give it a try and let you know if it makes a difference.
    Also do you know why it is bad to use ammonium hydroxide with chlorine in the pool? except that pool is unusable for few weeks. I read somewhere its effective against black algae.
  8. #28
    BigDave's Avatar
    You could break up a puck and put the chunks over the spots.
    I wouldn't advise ammonia products in a pool - PoolDoc or ChemGeek may be able to advise you better - I just don't have the depth or chemistry. I do know that you'd be likely to form chloramines and that monochloramine is an effective algaecide - is does stink and irritate skin. If you want to use the pool, I'd stick with shock FC levels and wear old swimsuits.
  9. #29
    The main reason ammonia products are used in a pool is that they form monochloramine that doesn't bind to CYA so in a pool with high CYA levels it's a way of "cheating" to get a higher active oxidizer level. This is especially true against algae that tend to look at monochloramine as if it were ammonia which is something they can use as a source of nitrogen, but the monochloramine kills them. However, your pool doesn't have very high CYA so shocking with chlorine should be quite effective. The key for black algae is to scrape off the waxy surface layer (the "heads") so that the chlorine can kill the algae below. Some people just maintain their pools at a somewhat higher FC level and brush regularly and the algae will slowly get killed while others go to shock level to try and get it over with more quickly -- up to you. At Ben's recommended FC/CYA levels, neither green nor black algae will be able to grow (yellow/mustard algae requires higher levels so is usually best to get rid of completely, if possible).
  10. #30
    May 2012
    Phoenix, AZ
    Thanks Chem Geek. I kept at shock level (15ppm+) for more than three weeks with daily brushing (yes daily, sometime twice a day) and for the last two weeks (of those three weeks) kept it at +shock+ (30ppm) level, still I could not get rid of all (or visibly none I should say) the black algae. Now I went back to keeping about 5-10ppm FC, since it got to a point where I had to say " I surrender" . So I was looking at any other options I may have, to remove them before I resort to acid wash (if thats the only way). I feel that I have a higher chlorine demand because of the black alage on the walls, they seems to slowly grow as time pass (unless I keep shock level chlorine levels as per Bens chart which is not practical for more than a month or so). I think I wasted a lot of money trying to figure this out, but no real end in sight **tired** So I am a bit desperate to know what I am doing wrong with my approach. I am sure you guys, chem geek/PoolDoc have seen and encountered all kinds of these issues in and out, either I am not giving enough info or there is no possible recourse with my issue(black algae) using BBB or I don't quite understand it. Thanks BigDave too for trying to get to the bottom of my issue.
  1. Concrete pool bottom dirty or cloudy or both?
    By matthewxcarroll in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-01-2013, 10:28 PM
  2. Cleaning up a very dirty pool with a DE filter
    By jrtredo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-27-2013, 12:48 PM
  3. Stuff on Bottom of Clear Pool... Brown Algae??
    By Tabisme in forum Dealing with Algae & Slime
    Last Post: 07-26-2011, 05:30 PM
  4. Why is my pool so dirty!!!
    By bizbad in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-26-2007, 05:27 PM
  5. Can I close a dirty pool?
    By housemom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-01-2006, 02:14 AM
