Results 1 to 10 of 12
Thread: Pool opening - 2013
    ajb8898 is offline Subscriber Thread Analyst ajb8898 0
    May 2012
    South Carolina
    Default Re: Pool opening - 2013
    OK sorry for the delay, I thought I'd get an email when someone replied.
    Yes, my husband dumped in TEN bags of powder when we first opened forgetting that it was only like TWO we were supposed to use. We are definitely only doing bleach from here.
    OK as for the Chlorine reading, I think I totally misread the instructions. Sorry, need to dust off my Taylor kit skills from my first year last year. I did the 10mL sample and counted 40 drops.
    The pH level didn't even register on the Taylor kit it was so low. I have an eXact digital reader (someone gave me) and it registered it as 6.4.
    Carl, what is DE powder?
    15K gal AG oval w/ Hayward sand filter; Taylor K2006C
    15'x30' oval 15K gal AG pool; bleach; Hayward sand filter; Hayward pump; 24hrs; Taylor K2006C; utility water; summer: ; winter: ; iPhone; PF:8
    May 2012
    South Carolina
    I got the pH up to 6.8 and added more Borax and then checked the Chlorine and it was down to 0 so I added bleach.
    The calcium hardness was only about 80-90 so it must be the dead algae.
    You're on the right track. DE is diatomaceous earth, used primarily in DE filters, one of the 3 common types of filter and usually described as "the best", in terms of its filtering capability. But a sand filter with a little DE in it can easily do as well.
    If you used 40 drops at the 10ml level your FC was 20ppm, what you need to keep it at as it dropped 0--meaning you are fighting an algae bloom.
    So...check your FC 2-3 times a day, adding bleach or liquid chlorine as needed to keep FC at 20.
    Brush your floor and walls once a day.
    Vacuum to wasted every day.
    Keep at it till the water is clear and the fc doesn't drop so dramatically.
    Let us know what's happening.
    May 2012
    South Carolina
    Everything seems to be stabilizing some. I'm not losing chlorine quite as quickly and I'm not getting as much dead algae floating to the top. Water is blue but still very cloudy, although less cloudy than it was.
    My issue is the pH doesn't seem to stay up. I keep having to adjust. Is that normal? What would cause that?
    Dichlor is somewhat acidic. Trichlor (sometimes sold as powder) is HIGHLY acidic. May be the cause of your pH problem.
    May 2012
    South Carolina
    I haven't used anything except bleach since that first time. Would that still be affecting it?
    May 2012
    South Carolina
    I'm continuing to deal with cloudy water. My skimmer sock keeps getting less and less dirty through the day so I hope that means it's slowly clearing out.
    I've been keeping my chlorine at 20--it's been several weeks now. Is it safe to have it at shock level for so long?
