Results 1 to 8 of 8
Thread: Saving money on salt
    Jul 2011
    Boca Raton, FL
    Default Saving money on salt
    Currently, I buy a 40lb bag of finely granulated salt at our local Pinch-a-Penny for $10 a bag. A different Pinch-a-Penny sells coarser salt for $8/bag. My equipment manufacturer (Jandy) says to avoid salt with Yellow Prussiate (I think that's what it's called?), and the Pinch-a-Penny salt doesn't have that ingredient in it (another nearer pool store sells salt with that Yellow stuff in it).
    What's the cheapest way to buy large amounts of salt that work properly with a SWCG, and don't have that Yellow Prussiate in it?
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Howell NJ
    Default Re: Saving money on salt
    Walmart has the cheapest morton pool salt @ 6 bucks. You cant beat that.
    http://www.walmart.com/ip/Morton-Sal...b-Bag/16561292
    12x18 vinyl AG 6.2K gal; Hayward equp: 16" sand filter (spring clean up) -- Xtream 100 sft cart (after clean up) -- Power Flo Matrix 1hp 2spd pump w/ AO Smith motor
    May 2012
    Virginia
    Smile Re: Saving money on salt
    Quote Originally Posted by Lawrosa View Post
    Sam's club sells pool salt for 5.49 for a 40 lb bag
    Belize 24 x 52 12,000 AG with blue wave sandman with a 1 1/2 hp sand filter. Plus a INTEX SWCG.
    ~Ivy~
    mas985's Avatar
    Pleasanton, CA
    Water softener solar salt is much cheaper. Just make sure it doesn't have any additives.
    http://www.lowes.com/pd_25656-113-73...alt&facetInfo=
    Mark
    Virginia
    Quote Originally Posted by mas985 View Post
    I used that one time and while it was cheaper, it was much coarser and seemed to take a long time to dissolve. Although more expensive, I much prefer the finer stuff.
    May 2010
    For no more than I need to add, I stick with the Morton Pool Salt. Do you drain and refill every year?
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by JimK View Post
    I put mine in the skimmer and it dissolves in a few minutes with the pump running.
    Mark
    Virginia
    Good idea. I'll have to give that a try sometime.
