Thread: Here we go switching to SWCG Question or two.
    May 2012
    Iowa
    Default Here we go switching to SWCG Question or two.
    Well my AG swcg arrived today http://www.autopilot.com/our-product...G-with-Floater.
    I couldnt find much in the way of reviews ect so I bit the bullet and pulled the trigger for $499. I checked my water today a came away with the following numbers.
    1.8 FC
    .08 CC
    7.4 PH
    70 TA
    45 CA
    I figured the Chlorine would be low as we had some stormy days where I left the pump off and did not do much with the pool for about a week. So I am in the process of getting that back up before I make the switch.
    My SWCG is a convection unit that will work without the pump running. Right now there will be no splash out for several weeks maybe more than a month.
    How much salt do I need to start with?
    Just plain old water conditioner salt is OK?? Kinda like bleach I am assuming that the bells and wistles for "Pool Salt" or anything else is either not necessary or may create other issues?
    Frequency of testing at start and once it stabilizes?
    I plan to take my water to be tested at the pool store before I make the switch. Or should I wait until after I think I have a stable water balance after the switch?
    Thanks in advance
    Bryan
    24 round 12.9K* gal AG vinyl pool; liquide chlorine; sand filter; 2 1 speed pump; 8 hrs; ; the recommended Taylor kit; utility water; summer: solar; winter: mesh; android phone; PF:9.3
    Default Re: Here we go switching to SWCG Question or two.
    The only switch you need to make is to salinate your water. You need a CYA level.
    Largo, Florida
    Is .08 CC a typo? I don't believe the recommended K-2006 kit reads more granularity than 0.2ppm.
  1. Switching from SWCG to liquid Chlorine.
    By poolaris in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-31-2013, 04:24 AM
  2. Question about switching from a pressure cleaner to a robotic one
    By TrunkMonkey in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-24-2011, 02:16 PM
  3. Livestrg05 - Newbie question about switching types of chlorine in green pool
    By Livestrg05 in forum Dealing with Algae & Slime
    Last Post: 04-21-2011, 05:55 PM
  4. SWCG Maintenance Question
    By BigTallGuy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 01-27-2011, 04:56 PM
  5. switching to bleach...one more question
    By mspool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2006, 03:49 PM
