Switching from SWCG to liquid Chlorine.
As I currently spend between 15-20 minutes a day in cleaning my salt gen cell I was thinking maybe I could save time and aggro by turning it off and simply adding liquid chlorine instead. My pool is about 14K gall, and cyanuric acid is at 50, I currently keep the CL level at 3.0.
Any idea how much liquid cl I would need to add, preferably every other day, to maintain that level?
Being in AZ the sun shines every day. I was hoping to offset some of the cost by reducing the amount of acid I have to add, which is usually 1 gall a week, and also of course the cost of replacement salt cells every other year. I normally use tablets only when I am away and would do so in the future as that way the pool does not build up high levels of cyanuric acid.
