Results 1 to 10 of 14
Thread: Switching from SWCG to liquid Chlorine.
    Ontario.
    Default Re: Switching from SWCG to liquid Chlorine.
    Phosphates are algae food, but because of the chlorine there is not algae, so the phosphates are not relevant. Phosfree at this point would be moot, unless there is some other reason than algae control.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    I'd lower your TA level as that should reduce calcium carbonate scaling on the tile. See the How To Guide to Lowering Swimming Pool Alkalinity.
  1. Here we go switching to SWCG Question or two.
    By bssage in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-10-2013, 10:51 AM
  2. Switching to Chlorine from Bromine in Hot Tub
    By petermoran in forum General Interest
    Last Post: 06-05-2012, 08:41 PM
  3. Re-balancing after switching to Chlorine
    By GeneNTN in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-06-2011, 02:48 PM
  4. Switching from Chlorine to Salt
    By kmmlangston in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-05-2010, 09:59 PM
  5. Liquid shock, bleach, liquid chlorine?
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 01:26 PM
