Results 1 to 10 of 39
Thread: Is my cell dying?
    Largo, Florida
    Default Re: Is my cell dying?
    When I'm done with mine, I neutralize it with baking soda then dump it to waste. I figure it's got all the calcium deposits that it cleaned from the cell in that water and I'd prefer not to put it back into the pool.
    You don't end up using very much acid at all when using one of the "holders". Only a cup or two if memory serves. You only have to mix up enough to fill the inside of the cell instead of filling a 5 gallon bucket to submerge the cell into.
    Virginia
    Quote Originally Posted by kelemvor View Post
    I considered doing the same, but it seems there are potential hazards (fuming, heat generated). I'd love to hear the details on how to do it this way (safely) and how much baking soda it takes to neutralize the acid solution.
    Largo, Florida
    I just dumped the acid solution back into a small bucket, then added baking soda slowly until there was no more noticeable reaction. Then I added a good bit more, and later dumped it and washed it away. It foams up a good bit when you start adding the soda.
    After cleaning up an accidental muriatic spill a month or two before I did the cell cleaning I was significantly less timid about things.
    Maybe someone else will have some more scientific details to share on the calculation to neutralize muriatic with baking soda.
    Virginia
    Do you have a general idea of how much baking soda you use? A few cups? Many cups?
    Largo, Florida
    Memory's a little fuzzy since it was last fall, but I think it was about 2 lbs (1/2 of one of the "large" boxes of arm and hammer). Since I had that acid spill I keep several boxes on hand at home "just in case".
    Virginia
    Thanks. I might give that a try the first time and see how it goes.
    Like you, I don't want to put the calcium back into the pool, but like was mentioned, it's probably an very insignificant amount. At least I know my options now.
    mas985's Avatar
    Pleasanton, CA
    Forgive me but that seems like a lot of trouble for so little CH compared to what is in the pool. 400 ppm CH in a 20 k pool is over 66 lbs. The amount on the cell is probably less than a couple of grams. Close to a 15000:1 ratio. Fill water probably adds more than that in a day.
    Mark
    Virginia
    Quote Originally Posted by mas985 View Post
    A couple grams is all? Put that way it does seem that putting it in the pool is the easiest thing to do without any real consequence.
    I greatly appreciate y'all sharing your experience using both methods.
