Maybe it's time to try a taylor k-1766 drop based salt test kit? My local pool store actually carries those.
Thanks for the suggestion.
I looked into that before and decided to go with the AquaCheck Salt Strips that were recommended here. I was told the strips do a good job (they seem to do fine).
I'll take a look at the Taylor kit again.
I'm wondering if the 300 ppm is simply the normal range of error. I think I remember years ago being told by the pool store that installed our system (I was having them test salt back then; they were using the Taylor kits) that it was normal to see a variation of 200 ppm or 300 ppm.
Test strip are fine IF they are fresh but they do seem to go bad quickly.
Mark
Meaning the salt test strips (and borate test strips). In case someone reads this out of context.Test strip are fine ...
Good point. Salt and borate are the only strips I use.
If my readings get too out of wack, I'll order the Taylor salt kit and give it a try.
I looked at the past few readings and noticed if the SWCG controller reading dropped 200 ppm so did the strip test reading. In other words, the 300 ppm difference between the controller and the strips has remained consistant, so I think I'm fine for now.
I've read that as a cell ages you can get lower readings, so I'm wondering if the age of my cell is what's causing the difference (this is our 6th season on this cell). Some have suggested only going by the controller reading since for the function of the SWCG this is what matters. However, I don't want to get into a situation of salt being way to high when it comes time to replace the cell. When the last cell died, the only indication I got was an unexpectedly low salt reading.
For now I don't plan to do anything as long as the controller reading and the stip readings (or Taylor kit if I get it) fall within the cell's normal operating range. Does this sound reasonable?
