Thread: Should I shock my pool upon opening, even if there is no algae build up?
    Oct 2012
    New Jersey, USA
    Default Should I shock my pool upon opening, even if there is no algae build up?
    Hi. My pool is a 20x40 in-ground with 40,000 gallons of water and a vinyl liner. I'll be opening it on the weekend. When I closed it in October, it was absolutely crystal clear and spotless, and the other day I pulled up a corner on the (solid) cover, and it seems to still be completely clear.
    Considering this, would it be a good idea to use shock to get the chlorine levels up asap, or would standard chlorine/bleach treatment be fine since there is no algae problem?
    Thanks!
    Virginia
    Default Re: Should I shock my pool upon opening, even if there is no algae build up?
    Quote Originally Posted by Racker View Post
    Thanks!
    I always shock to kill/burn off other things that are in there besides algae. My pool is also clear when I open it, but it's obvious from the chlorine consumption after shocking that there are other contaminants that have to be cleared up.
