Thread: Measuring Chlorine?
    Midwest
    Default Measuring Chlorine?
    Do you use a measuring cup or just eyeball it?
    Add at night?
    BigDave's Avatar
    Default Re: Measuring Chlorine?
    I measure it using a plastic beverage cup (red Solo cup). I hold the bleach bottle and the cup over the pool water when I pour to make less mess. I usually test then dose after I get home from work.
  1. Measuring sodium tetraborate (borax)
    By Rebecca in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-15-2012, 07:11 PM
  2. Proper Measuring Level BBB (Hot Tub)
    By mjones0089 in forum General Interest
    Last Post: 06-29-2012, 05:45 PM
  3. Measuring Height for Liner Replacement
    By cooper in forum Above-Ground Pool Construction & Repair
    Last Post: 05-12-2011, 01:05 AM
  4. ML measuring container
    By donfranko in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-02-2010, 12:27 PM
  5. Measuring Cyanuric Acid - can this help?
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-04-2008, 11:46 PM
