Thread: aquabot power supply not working
    Default aquabot power supply not working
    I moved my power supply for my aquabot turbo, and firmly unpluged the connection from the blue line from the unit into the power supply. Unfortunately, I pulled out the black plug inlet in the power supply, and I see a hanging white wire. I assume it is a ground and goes to the middle connection on the back of the plug inlet, and I attached it. The unit still does not go on. When I plug in the power supply, and power it up, I can feel it vibrate, so it is doing something, but the timer light does not come on at all. This thing will cost about $200 to replace, so any suggestions are appreciated!
    I checked the other two connections to the plug inlet (black and green wire), and they are firmly connected. The unit never seemed to work as it was supposed to, but flipping the power on/off, resetting the timer a few times, etc. would make it start. I just can't get it to work at all now.
    - betty
    Default Re: aquabot power supply not working
    moving tnis to cleaning thread if interested
