A few days ago, I thought maybe something was living in my filter cartridge, so I removed that and continued with my program of keeping the pool at shock level. Still no change. Also, I thought it might be the amonia issue due to degraded CYA because I had that problem last year. I have a 40-50 CYA reading this spring which is only down slightly from closing last fall. There was a lot of pollen a week ago, but has since not been an issue.
My plan is to continue with holding above shock, but this is getting ridiculous!! Like I said, the water is crystal clear and inviting. No visible signs of any issue other than my crazy chlorine readings....
16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
Ok....this is getting frustrating! My FC went from 35.5 last nite at 11 pm to 19.5 at 8 pm tonite. This is getting expensive. There must be a problem that i cant figure out. I am about to recover this pool and call it a day!
Since you said you checked your filter, I assume you checked other places such as your skimmer and pump basket. You might also check under any removable ladders and perhaps behind light niches. Something is seriously consuming chlorine in your pool, and losing it overnight means it's not the UV in sunlight.
I also assume you test your chlorine level within an hour after you've added it just to make sure your chlorine isn't weaker than you think. So I too am at a loss. This is very unusual. Even if it were some conversion of CYA to ammonia and/or partially oxidized CYA, you should see your chlorine demand dropping and you would see at least some CC.
Yes, I do check chlorine levels after adding. For example, last night at 9 PM I added 8 gallons of 6% bleach and raised my FC level from 19.5 ppm to 42-43 ppm which it tested at 11 PM. This morning at 7 AM, my FC level was 37 ppm, for a loss of 4-5 overnight. I had a similar loss the night before of 5-6 ppm. No cc reading this morning, either. I will check behind my light housing today. Pump basket is clean. Under ladder looks clean, too.
I am at a loss here and it is getting very expensiive!!
The reason I took it up to high 30's for FC is that keeping it at the shock level recommended by the BBB method wasn't working. The chart recommends 20 ppm for shock level for me.
Is it at all possible that you're testing CC and FC out of order? I'm sorry for asking, but I've been puzzling over this issue. The FAS-DPD test method is:
Measure pool water sample(I'm presuming 10ml)
Add a scoop or two of R-0870 DPD powder and swirl until solution turns pink.
Add the R-0871 titrating solution counting each drop and mixing.
Multiply drop count by 0.5ppm to get FC reading.
Add 5 drops of the R-0003 DPD Reagent #3.
If the solution turns pink again:
Add R-0871 solution counting each drop and mixing.
Multiply drop count by 0.5ppm to get CC reading.
I hope you're not offended, this is a real headscratcher.
Ha...not offended at all. In fact my son asked me the same thing. I am testing properly I believe.
I just tested again at 10 AM. My FC is now down to 28-29 ppm (last nite at 11 PM it was 43!). I didnt believe those results so I tested it a second time and got the same number. Also, I did get a slight reading on cc this time, too, of 0.5<. Also, the water is crystal clear.
I am starting to think that draining the pool down by half and re-filling might be a cheaper way to go.
Any thoughts??
