Hi, Lou,
I think you might be on the money suspecting precip as your issue. Normally, I would think you'd need some Cl (and you might still) but I believe your diagnosis is very good.Any comments on these numbers? Is my hunch about Precipitation due to High PH correct?
Your CYA is sky high but manageable if you keep your Cl levels way up.
If your pool doesn't clear nicely by lowering the pH (I think it may very well) you'll want to shock with a pretty massive dose of Cl....25ppm. Then assuming it clears from either the pH adjustment or the shock, you should be up around 8-15ppm Cl all the time with that CYA of 100.
You've done a nice startup, Lou...good work recognizing your issues immediately. Thanks for those test results....it makes everything soooo easy.
