Hi again
Time for a good dose of POP (Pool Owner Patience)
It sounds as if you have enough chlorine in the pool to 'work on' the algae. Please let the pool go until tomorrow - stop stirring up the stuff, let it settle so you can see what you need to vacuum to waste.
I suspect that you want to have a pool party this weekend for Memorial day. You can use DE to assist your sand filter or a flocculant to speed up the water's clearing. You could also 'vacuum blind' and hope to remove the majority of the 'stuff' on the bottom - if you go this route, push the vac-head slowly, so as not to stir too much up.
You can use the feeder. (however, I think your CYA = 35 is fine for the Cape.)
We're here to help, but there is no miracle nor instant fix.
