Re: aquabot power supply not working
I had the black socket crack on my unit recently, and there was no way to get the plug in to it.
Here is what I did to repair it-
Open up the unit by drilling through the 4 rivets on the sides
You will then see the wires that are attached to the socket.
To test to see if the problem is a bad connection at the socket, manually place the ends of the 2 wires into the aquabot's plug. Turn the power on, and see if the aquabot moves.
If it does, you will need to buy a new socket...I paid $9.00 online plus shipping.
Install the new socket,rivet the cover back on, and you're in business.
Hope I have made it clear, if not let me know.
Good luck
