Thread: Adjusting TA with muriatic acid
    Aug 2012
    Maine
    Default Adjusting TA with muriatic acid
    Hello! So I'm starting up my Intex 3800 gal pool w/ SWCG this week. So far I've got:
    TC: 2.5
    PH: 7.4
    TA: 170
    CH: 100
    CYA: 35
    According to my hand little Taylor guide, TA seems pretty high and the calcium pretty low. If I add a bunch of muriatic acid to bring the TA down to, say, 100, how do I bring the pH back up to 7.4 without bringing TA up too? And if I add some calcium chloride to bring up the CH, what effect will that have on my pH?
    This is my second year with this pool, and already I'm off to a better start than last year, but I've still got some stuff to learn for sure!
    Jul 2012
    Mexico, Missouri
    Default Re: Adjusting TA with muriatic acid
    Suggested reading are these two sections from the sister site to these forums, Poolsolutions.com:
    http://poolsolutions.com/gd/total-al...ing-pools.html
    and
    http://poolsolutions.com/gd/lowering...p-by-step.html
    These two sections have the information that might be pertinent to your question.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    BigDave's Avatar
    Charlie_R's reading suggestions are spot-on. Id also suggest Using Muriatic Acid to Safely Lower Your Pool's pH.
    Don't bother with Calcium. It really only matters for concrete pools.
    I worry when I hear "add a bunch of muriatic acid" add a little at a time let it mix then test again. Aeration will bring your pH back up.
