Thread: How to fix the rust in pool metal walls!? [pics included]
    May 2013
    Default How to fix the rust in pool metal walls!? [pics included]
    There supposed to be a lining but it broke and we r planning to buy a new one
    Default Re: How to fix the rust in pool metal walls!? [pics included]
    You can probably fix that -- for 5 - 10 years -- with flat section cut from a new galvanized pool wall section. You'll need some high grade duct tape, some basic sheet metal skills and tools, and maybe a pop-rivet gun. If you grind the rusted section, and paint with a zinc rich paint. Here are some links:
    Info:
    http://www.briteproducts.com/zincpaint.php
    http://www.galvanizeit.org/specifyin...ing-hdg-steel/
    Safety:
    http://www.amazon.com/exec/obidos/ASIN/B000RKS04G/poolbooks
    DEWALT DPG82-11C Concealer Clear Anti-Fog Dual Mold Safety Goggle
    *OR*
    Dewalt DPG20M All Purpose Synthetic Leather Palm Spandex Back Velcro Wrist Work Glove, Medium
    Surface prep & repair:
    Bosch 1380 Slim 7.5 Amp 4-1/2-Inch Slim Grinder
    DEWALT DW4523 4-1/2-Inch by 1/4-Inch by 5/8-Inch General Purpose Metal Grinding Wheel
    Rust-Oleum 7585838 Professional Cold Galvanizing Compound Spray Paint, 20-Ounce
    *OR*
    CRC Industries 18412 Zinc-It Instant Cold Galvanize Zinc Rich Galvanize Coating
    Sheet metal patch:
    Wiss M300 MultiMaster 3-Inch Cut Capacity 10-1/2-Inch Straight, Left, and Right Cut Long Handled Snip
    Stanley MR100CG Contractor Grade Riveter
    Stainless Steel Blind Rivets, Inch, Meets IFI Grade 50 Specifications
    Scotch Heavy Duty All-Weather Duct Tape, 1.88-Inch by 45-Yard
    Notes:
    + I'm no longer actively buying construction tools. But the contractors I've talked to recently all seem to feel Dewalt has good price/quality characteristics, and that Bosch tools are very good, when they are not too expensive. Milwaukee 'ain't what it used to be'.
    + Do NOT use cheap duct (not: duck!) tape. You'll regret it.
    + You can try the repair without the patch, but you'll likely get better results if you do both. You'll have to get a pool dealer to sell you a galvanized wall section, unless you can find heavy galvanized sheet metal elsewhere. Do NOT use electroplated duct-work sheet metal; the galvanizing won't last long.
    + These are all Amazon links; you can probably find most of these things locally; however Amazon has a great return policy . . . if you return them promptly. So, don't order them till you are ready to go to work. That way you can test them immediately, and return them right away if you are unlucky and have a problem.
    + Depending how high the concrete was poured at the bottom of the pool wall, you may not be able to drill and pop-rivet all the way down.
    + Aluminum pop-rivets *may* be OK in this application, but I'm not sure. I *know* SS rivets will last.
  1. Portable home made vacuum HELP! PICS INCLUDED
    By Antman2x2 in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-12-2012, 07:23 PM
  2. Two Rolls Of Metal For The Side Walls On A 30' Pool?
    By SooperDave in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2012, 02:56 PM
  3. How would you backfill this (picture included)
    By idohair2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-27-2011, 11:43 AM
  4. inward bulging of side walls on rectagular metal frame pool
    By Sacto in forum In-Ground Pool Construction and Repair
    Last Post: 05-05-2011, 02:55 PM
  5. Help with rust on bottom of walls
    By Karen_in_TN in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2008, 01:17 AM
