Results 1 to 10 of 25
Thread: Help a newbie?
    GlenKlein is offline ** No working email address ** GlenKlein 0
    Default Re: Help a newbie?
    Hi all,
    Thanks for your quick replies... I went out and got the kit and will post numbers tonight.
    In the meantime, I got the name of the 70# bucket from Sam's Club:
    ProCare Granular Chlorinator
    99% Sodium Dichloro-S-Traizinetrione Dihydrate
    I'll get back to you with the numbers and thanks for all the help!
    Glen
    Quote Originally Posted by GlenKlein
    Hi all,
    Glen
    That is what we usually just call dichlor. It is a fast dissovling stabilized chlorine that has minimal impact on pH. It is fine to use for both regular sanitation and shocking until your CYA levels get too high (if you use it to shock this can happen quickly, you might want to use bleach to shock so you can get the maximun use out of the dichlor). IF you use it until your CYA gets to about 30-50 ppm and then switch to bleach you should be fine. This way you don't have to add stabilizer as a separate chemical. It was actually a good choice for a newbie with a new vinyl pool! You still have to get your water balanced so get those test numbers posted ASAP!
    ok... ran my Walmart test kit.
    Please note - on Sunday I put 2 cups of the ProCare stuff in.
    Chlorine/Bromine test = ORANGE (off the chart - the chart ended at yellow - my color was almost like a peach orange)
    Alkalinity = 330ppm total alklinity as calcium carbonate
    pH = 7.5
    Hardness = my water didn't turn red as the test said it should.
    CYA = 30ppm - the solution never got cloudy enough to hide the black dot.
    Hope that tells you guys something - cuz it means nothing to me right now.
    Thanks for your help!
    That means your chlorine levels are high. That is where you want it if your water is green from algae. You can extend the scale of your kit by diluting the pool water sample with distilled water. If you dilute 1:1 multiply the test results by 2, 1:2 (1 part pool water to two parts distilled) multiply by 3, 1:3 multiply by 4 and 1:4 mulitply by 5. I would not try to dilute any more thant 1 part pool water to 4 parts distilled water but you have just increased the range of this test up to 25 ppm TC with a slight loss in accuracy!
    Don't try and use this test for FC readings. It really doesn't work. OTO reagent only accurately measures TC!
    This will need to be lowered once you get rid of the green water! When you are ready post a thread on how to lower the TA in the appropriate colomn and read the FAQ on the subject in that forum.
    pH = 7.5
    Perfect, you want to stay between 7.2 and 7.6
    This test in this kit has some problems, it might be the high chlorine levels interfering. At any rate you have a vinyl pool so this parameter is not important for you
    Your CYA is below 30 ppm. As you continue to use the dichlor this will rise. Stop using the dichlor and switch to bleach when it hits about 50 ppm and you will be fine.
    The other thing you might want to do is take a sample of water to a pool store and get it tested for metals since you are using well water. If you have metals in the water using a sequestering agent is a good idea. Copper can make the water clear green. I assume your green is from algae but it can be hard to tell without tests for metals and FC. If it is algae then your FC won't be holding and the pool might be cloudy green and have a slimy feel. If it is copper the water can be light green to emerald green. Iron can color the water yellow and if your liner is blue it can make the water look green.
    The treatments for these two problems are different and the algae treatment can make the water look worse if it is caused by metals.
    If the green is from algae (water might be cloudy and pool will feel slimy) you need to get your chlorine levels to about 10-12 ppm and KEEP THEM THERE until the pool clears while running the pump 23/7 and cleaning the filter as often as necessary. Once the algae dies the pool might have a cloudy look to it from the dead algae. Your filter will take care of it but you might need to be patient.
    If the green is from metals (water is very clear but has a color to it, pool has no slimy feel) a treament with a sequestering agent such as Jack's Magic or Proteam Melal Magic will take care of the problem. This is not a 'one time fix' and maintenence doses of the sequesterant will probably be needed on a regular basis and every time you add water so the problem doesn't return.
    Next step is to get a sample to the pool store and let them test it for metals but DO NOT BUY ANY PRODUCTS FROM THEM until you post the results!
    Thanks Evan - I also forgot to mention:
    I noticed an orange residue on my skimmer basket - it almost looks like my skimmer basket is rusting! I tried to wipe it off and it was pretty stubborn (if that tells you anything else).
    I'll get to studying your notes!! Thanks so much for your help!
    And BTW - the water is clear... emarald green was a good call. There is no slimy feel to it at all, and my inner liner is mostly white with a blue pattern. Also, the water's only been in the pool for 3 days now and it was emerald green as soon as it was full (the first morning). Doesn't algae take a while to form?
    And BTW - the water is clear... emarald green was a good call. There is no slimy feel to it at all. Also, the water's only been in the pool for 3 days now and it was emerald green as soon as it was full. Doesn't algae take a while to form?
    Algae can form pretty quickly but the color from metals usually happens when high chlorine levels oxidize the metals in the water and usually appear soon after the chlorine is added. At this point I would try getting a bottle of sequesterant and FOLLOW THE DIRECTIONS ON THE BOTTLE in terms of chlorine levels and pH needed when you apply it. I have used Jack's Magic and Proteam Metal Magic and they are both good but there are many good ones out there. It won't really hurt anything if you don't need it and if it is what you need it will work like magic. You can try rubbing the orange stain with a vitamin c tablet and see if it lightens or disappears. If it does then the problem is definitely iron! Post your findings.
    Hi Evan,
    I just wanted to ask if there's any possibility of the greenish color coming from sand? We don't live far from Lake Michigan, and the soil around here is sandy... shot in the dark, but wanted to ask.
    And also in case it matters - the orange rusty stuff did wipe off of the basket, I just had to rub it vigorously - (otherwise, I would've tried the vitamin C thing).
    We live out in the sticks, so I'll have to try and find a nearby pool store for testing... might be difficult, but I'll find out today.
    Thanks - Glen
