Results 1 to 10 of 25
Thread: Help a newbie?
    GlenKlein is offline ** No working email address ** GlenKlein 0
    Default Re: Help a newbie?
    Hi Evan,
    I just wanted to ask if there's any possibility of the greenish color coming from sand? We don't live far from Lake Michigan, and the soil around here is sandy... shot in the dark, but wanted to ask.
    And also in case it matters - the orange rusty stuff did wipe off of the basket, I just had to rub it vigorously - (otherwise, I would've tried the vitamin C thing).
    We live out in the sticks, so I'll have to try and find a nearby pool store for testing... might be difficult, but I'll find out today.
    Thanks - Glen
    Especially since you don't live close to a pool store, you need the capability to test your own water reliably. (Actually, everyone does, regardless of where they live. Testing your own water is always better than relying on a pool store.) Consider buying the kit that most of us use from the sister site to this forum www.poolsolutions.com .
    http://www.poolsolutions.com/cart/ps234.php
    Quote Originally Posted by Watermom
    I was suggesting in an earlier post that he have his water tested for metals. Unfortunately, most test kits, including Ben's, don't test for iron and copper. That is why I suggested the pool store. He has the walmart kit.
    Quote Originally Posted by GlenKlein
    Hi Evan,
    Don't have a clue. Sorry. Kinda doubt it though.
    Might be from iron or something else.
    You could purchase test kits for iron and copper but they are probably an unneeded expense. Once you know what is in your water you will know what to treat it with to keep it under control.
    Thanks - Glen
    Hope this helps.
    Hi Evan,
    First - thanks for your patience with me... you've been VERY helpful.
    Second... after giving some thought to your answers, I am convinced that my water is YELLOW and that you were right... the blue in the liner makes it look green.
    I went to Walmart yesterday and bumped into another guy on well water... he said to get muriatic (sp?) acid and that would clear it up????
    I looked online for your suggestions to clear up the iron and the Jack's stuff had a pink and a blue version? I'll go back this morning and read the descriptions again, but it didn't appear to be clear to me - which one to order?! I think I want the Blue Stuff (because it's stable in high chlorine and removes iron) but it sounds like that was designed mostly for plaster pools?!
    Thanks again... I'm learning a ton if that's worth anything!
    no reply necessary... I found the Proteam Metal Magic nearby. I'm gonna give that a shot first.
    I'll let you know what happens.
    Metal Magic will work fine. As far as the Jack's....the Pink stuff is what you want. the Blue Stuff is stronger and works better on high copper concentrations in the water.
    Perryville, Missouri, USA.
    You cant help but learn a ton with these folks. They really know what they are doing and will help you with just about anything pool related.
    Reading this thread brings me to a question: I too am on a well, but I cannot take water to a pool store to test for metals because the results always involve selling something and they dont actually give you the results of the test, its just "put this in and it will fix you up". Is there a test kit available for metals to end users?
    Indiana.
    Quote Originally Posted by Chaotic
    http://www.poolstore.com/store1/welc...per/index.html
    Thank you. I assume the copper and iron reagents have a 1 to 2 year life?
