Re: Help a newbie?
New numbers -
5/30/06 - Chlorine/Bromine test = ORANGE (off the chart - the chart ended at yellow - my color was almost like a peach orange)
6/3/06 - Chlorine = 1 (a few days ago it was off the chart - see above)
5/30/06 - Alkalinity = 330ppm total alklinity as calcium carbonate
pH = 7.5
6/3/06 - Alkalinity = 300ppm
5/30/06 - Hardness = my water didn't turn red as the test said it should.
6/3/06 - this time the water did turn red - so Evan, you were probably right. The high chlorine was messing with the hardness test.
5/30/06 - CYA = 30ppm - the solution never got cloudy enough to hide the black dot.
6/3/06 - still the same as above.
I think the metal magic may be working btw. It is a little clearer this morning - not quite so green (see post right above this one for orange stuff comments).
I followed the directions on the bottle of the metal magic. 16oz for 5000 gallons... I'm wondering if I can go ahead and dump the remaining 16oz. and hopefully clear it up even more?
Also my Chlorine level really went down in a matter of a few days - so maybe it is an algae thing afterall?
