Re: Help a newbie?
Thanks Carl,
I added more dichlor - Evan said I should wait until my CYA is 50ppm, and then switch to bleach? I will check the Chlorine a little later again.
Also note: I just pulled my filter, and as you might've guessed - it too was pumpkin orange. I just rinsed it out under hot water and it cleaned right up - no problem.
Re: Help a newbie?
You need to raise CYA a little, but anywhere between 30 and 50 is fine. I actually like 40ppm. At that point you stop using di-chlor and switch to bleach. You can, however, follow Evan's advice with confidence--I'd stop sooner than 50ppm but that's me.
