Results 1 to 9 of 9
Thread: Replacing Coping
    Boston area
    Default Re: Replacing Coping
    Here's a picture of one of the more damaged areas. The top of the picture is the edge of the coping, under which there should be two layers of tile - one matching the tiles you can see under the waterline (at the top) and one, about double the height, between the two.
    Pool: 25K gal - In-ground / Gunite ● Pump: American Products 384484 1.5 HP ● DE Filter: American Products Titan CM #57025000 48 ft^2
    Valve: American Products 2.0" Side Mount Multiport 501692 ● Lights: American Products Model R-300 BC ● Cleaner: Hayward Pool Vac Ultra, 2005C
    Marin is offline In the pool biz Thread Analyst Marin 2 stars Marin 2 stars
    Jun 2013
    Oklahoma
    Can you post a top view?
