Thread: Pool girl
    May 2013
    Columbus,Ohio
    Default Pool girl
    I recently came back to the homestead when my father passed & my mom needed care. I have a L shaped pool. I just replaced the sand filter & new hayward pump. I would like to know what order should you add Chemicals? And they timing in between I just opened the pool on Memorial day and all my levels are low. The Ppm confuses me as well oh I am i central n Ohio
    It has been 80 low 90s the last 2 days here.
    Any advice welcome
    Anastasia
    Default Re: Pool girl
    An L-shaped in-ground is probably in excess of 25,000 gallons. If you'll dump 3 gallons of PLAIN 6% household bleach in the pool EVERY evening, that should hold you till you can work down the list below.
    1. Order a K2006 test kit (see below for link)
    2. Purchase a plain OTO/phenol red kit locally (yellow/red drops). Use it, and report results.
    3. Measure the pool:
    --> Length of each side of L
    --> Width of each L end
    --> Depth at each L end
    --> Location of deep end (short side; long side of L?) if there is one
    --> Depth of deep end, if any.
    4. Report this info, and we can work out a chemical plan
    5. Hire someone -- pool guy -- to show you how to operate the pool equipment. Ideally, have a 3rd person video as they show you.
    May 2013
    Columbus,Ohio
    I have an hth 5 way drop kit. Levels are CL 5 ph 6.5 alk 40. Cya 70. In the last 24 hours I added in order 3lbs baking soda, 4 lbs borax now 5 gallons bleach.
    + Read the Best Guess Chlorine page, linked in my signature
    + Hold your chlorine level in the DARK yellow range, till you have the K2006.
    + Unless your pool is concrete, do not add any more baking soda or calcium hardness.
    + Use borax (Walmart detergent section) to raise pH to 7.2 or so.
    May 2013
    Columbus,Ohio
    How much borax should I use? pH is 6.5 for a 35k gallon pool. Vinyl liner. I also have white foam in the skimmer & a lot of cloudy floaters. Should I scoop out the foam? I am also running my cleaning robot thanks for replying Pooldoc
